7 years, 10 months ago.
DMA using
How can I implement DMA for generating 100kHz sine via DAC?
My board is nucleo STM32 L476RG
7 years, 9 months ago.
Hello Igor,
You can't implement a DMA on the nucleo STM32 L476RG because the board does not support DMA. You still, however, able to generate a 100kHz sine via the DAC.
Here is an example code
100Khz sine output
// DAC 100khz
#define DAC_Frequency 100000
AnalogOut dac(PA_4);
DigitalIn btn(USER_BUTTON);
Timer tim;
Ticker tic;
//sine table for a 12bit day
static volatile uint16_t sinetable[] = {
2047, 2147, 2248, 2348, 2447, 2545, 2642, 2737,
2831, 2923, 3012, 3100, 3185, 3267, 3346, 3422,
3495, 3564, 3630, 3692, 3750, 3804, 3853, 3898,
3939, 3975, 4007, 4034, 4056, 4073, 4085, 4093,
4095, 4093, 4085, 4073, 4056, 4034, 4007, 3975,
3939, 3898, 3853, 3804, 3750, 3692, 3630, 3564,
3495, 3422, 3346, 3267, 3185, 3100, 3012, 2923,
2831, 2737, 2642, 2545, 2447, 2348, 2248, 2147,
2047, 1948, 1847, 1747, 1648, 1550, 1453, 1358,
1264, 1172, 1083, 995, 910, 828, 749, 673,
600, 531, 465, 403, 345, 291, 242, 197,
156, 120, 88, 61, 39, 22, 10, 2,
0, 2, 10, 22, 39, 61, 88, 120,
156, 197, 242, 291, 345, 403, 465, 531,
600, 673, 749, 828, 910, 995, 1083, 1172,
1264, 1358, 1453, 1550, 1648, 1747, 1847, 1948,
int sel = 0;
void DAC_Int(void)
// Sine wave
dac = sinetable[sel];
sel = (sel+1)%(sizeof(sinetable)/sizeof(sinetable[0]));
tim.start();
tic.attach_us(&DAC_Int, 1000000 / DAC_Frequency);
while(1)
- Peter, team Mbed
Thanks for your answer!
So sad if mbed library does not support that periphery. I am already made that sine generator using DMA controller embedded in L476RG, but I used C code from CubeMX library. It was inefficiently for a next develop. Therefore I looking for C++ library with similar functions.
posted by 01 Jul 2018
