7 years, 9 months ago.
I can't export from MBED to Keil
I have LPC 824 MAX and I want to export my MBED codes from online complier to Keil uVision 5. Export toolchain section hasn't uVision 5 option. So, I can't export. How can I fix this problem. Thank you for your helps.
/media/uploads/Alperen/ads-z.png
Hi Alperen, I'm looking into this for you.
- Jenny, team Mbed
posted by Jenny Plunkett 11 Jun 2018
Hi Alperen,
I've created a GitHub issue for this on the Mbed OS repository, you can check on the status of it here: https://github.com/ARMmbed/mbed-os/issues/7184
- Jenny, team Mbed
Hi Jenny,
Thank you for your helps. I found a point about online compiler. When your cursor on the QtCreator section, you can reach uVision 5 section by the press the down button twice. But now, MBED online complier gives to error abaout ARM build.
posted by Alperen Yazar 13 Jun 2018
  • about
That is interesting. I'll let our online compiler team know about it. Thank you!
- Jenny, team Mbed
posted by Jenny Plunkett 13 Jun 2018
Assigned to Alperen Yazar 7 years, 9 months ago.
