7 years, 9 months ago.
Can I measure noise level or SNR using mDot?
Some of my places have a very high noise level, my program set the lbt's threshold at -80 dBm. When my mDot want to join the network, it will always say the channel is busy. Can I use mDot to measure noise level or SNR? I want to find out the suitable lbt's threshold.
The MultiConnect® mDot™ offers significantly longer range and improved radio performance compared to traditional wireless solutions—resulting in greater transmission range and reduced capital expense.
Hello there,
Here is a Reference Guide of AT Commands which includes a command to display the signal to noise ratio (starting on page 79):
https://www.multitech.com/documents/publications/manuals/s000643.pdf
Here is an AT Command parser which you can use as well if you'd like:
https://github.com/ARMmbed/ATParser
Hope this helps!
-Karen, team Mbed
Hi Karen, the reference link seems not working.
posted by Jiayao Gao 25 Oct 2018
