7 years, 10 months ago.
how to disable SPI for power savings, nRF51822
Hi, I'm using nRF51822 along with a SPI sensor. I'm following this example on MBED.
https://os.mbed.com/users/jejuho/code/VTT_NODEV3_LIS3DH/
When I go to sleep via ble.waitForEvent(), I'm consuming about 300uA. This should be closer to 4uA. Without any of the SPI code, I get around 4uA. I googled how to enable/disable it, but I'm not sure is that's proper.
Is this correct?
NRF_SPI0->ENABLE = 0; disable
NRF_SPI0->ENABLE = 1; enable
#include "LIS3DH.h"
#include "ble/BLE.h"
#define MISO p4
#define CS p3
#define SCLK p7
static LIS3DH lis(MOSI, MISO, CS, SCLK);
float x,y,z;
InterruptIn button1(p1); //nRF51822 P0.0
AxesRaw_t accel_raw;
bool flag_read_acc;
//ISR for I/O interrupt
void button1_int(void)
//set flag on interrupt
flag_read_acc=1;
int main ()
//pc.baud(9600);
//pc.printf("...started... \n\r");
//Initialize SPI interface
SPI spi(MOSI, MISO, SCLK);
spi.format(8,3);
spi.frequency(8000000);
BLE &ble = BLE::Instance();
ble.init(); //using this just for sleep
//Initialize LIS3DH driver
lis.InitLIS3DH(LIS3DH_NORMAL, LIS3DH_ODR_25Hz, LIS3DH_FULLSCALE_2); //Init Acc-sensor
//enable threshold to generate interrupt
lis.SetLIS3DHActivityDetection(10, LIS3DH_INT_MODE_6D_MOVEMENT, 1);
//set interrupt pin
button1.mode(PullDown);
button1.rise(button1_int);
lis.LIS3DH_ResetInt1Latch();
while (1) {
if (flag_read_acc == 1)
//do stuff in this routine
flag_read_acc=0; //reset flag
}//end if flag
lis.LIS3DH_ResetInt1Latch(); //move this to when you really want to release
NRF_SPI0->ENABLE = 0; //disable SPI?
ble.waitForEvent();
NRF_SPI0->ENABLE = 1; //re-enable SPI
}//end while
}//end main()
7 years, 5 months ago.
Hi Eric
Did you ever get this to work. I cant seem to get rid of the 400ua power consumption at sleep after I have used any SPI devices!?
Hello Eric,
Yes you are correct. I am not sure if you have seen this discussion post on the Nordic website when searching around, but it goes over the board’s low power modes in more detail:
Here is also their reference manual which details the enable/disable:
http://infocenter.nordicsemi.com/pdf/nRF51_RM_v3.0.pdf
Hope this answers your question!
-Karen, team Mbed
Hi Eric
posted by Ben S 21 Oct 2018
