7 years, 9 months ago.
How to speed up connection using LoRaWANInterface?
I'm using a DISCO-L072CZ-LRWAN1 to design a basic humidity sensor that sends the data via LoRa to a gateway. The eventual application will be battery powered. The application is built as stated here: https://os.mbed.com/docs/v5.8/reference/lorawan-api.html
It works but it takes up to a minute to connect to the gateway and start sending data, which is far too long for the battery powered version. What is causing it to take so long? And is there a way to speed it up?
LoRa Humidity Sensor Main
int main (void)
lorawan_status_t retcode; //Stores the status of a call to LoRaWAN protocol
if (lorawan.initialize(&ev_queue) != LORAWAN_STATUS_OK) { //Initialize LoRaWAN stack
pc.printf("[ERROR] LoRa initialization failed! \r\n");
return -1;
pc.printf("Mbed LoRaWANStack initialized \r\n");
callbacks.events = mbed::callback(lora_event_handler); //Prepare application callbacks
lorawan.add_app_callbacks(&callbacks);
if (lorawan.set_confirmed_msg_retries(CONFIRMED_MSG_RETRY_COUNTER) //Set number of retries in case of CONFIRMED messages
pc.printf("[ERROR] set_confirmed_msg_retries failed! \r\n\r\n");
return -1;
pc.printf("CONFIRMED message retries : %d \r\n",
CONFIRMED_MSG_RETRY_COUNTER);
if (lorawan.enable_adaptive_datarate() != LORAWAN_STATUS_OK) { //Enable adaptive data rate
pc.printf("[ERROR] enable_adaptive_datarate failed! \r\n");
return -1;
pc.printf("Adaptive data rate (ADR) - Enabled \r\n");
retcode = lorawan.connect();
if (retcode == LORAWAN_STATUS_OK ||
retcode == LORAWAN_STATUS_CONNECT_IN_PROGRESS) {
} else {
pc.printf("[ERROR] Connection error, code = %d \r\n", retcode);
pc.printf("Connection - In Progress ...\r\n");
uint32_t val;
val = get_hum();
pc.printf("Read humidity value: %i \r\n", val);
ev_queue.dispatch();
wait_ms(30000);
return 0;
