7 years, 10 months ago.
why it shows like Error: Target "DISCO_L072CZ_LRWAN1" is not recognized ?
/media/uploads/HarishKumarBringi/2018-05-31.png Hello, Do anyone know why it shows like this ? I am using the code which is used for STM32F4 Disco, I am using STM32l072 Disco. Will that be a problem ? If yes, what should I change ? Thank you in Advance./media/uploads/HarishKumarBringi/2018-05-31.png
Hi Harish,
Can you check that you are using the proper USB port as shown in the user manual for this board: http://www.st.com/resource/en/user_manual/dm00329995.pdf
You might also need to update the board's ST-Link firmware as described in Section 8.2 of the user manual.
As for using code that was developed for another processor - yes that could certainly pose a problem. You will need to compare the data sheet or user manual for the two devices to see what risks you are taking. We suggest starting with the memory map and peripherals being used.
-Ralph, Team Mbed
-Ralph, Team Mbed
