7 years, 6 months ago.
stm32L476 - Blinky Example
How can i modify the code to print "good bye" every time the LED turns off?
Hello Moe,
To print “goodbye” when the LED turns off, you can create an if statement within the while loop:
DigitalOut led1(LED1);
// main() runs in its own thread in the OS
    while (true) {
       led1 = !led1;
      //new code
       if(!led1){
	     printf(“Goodbye!!\n\r”);
       wait(0.5);
This will allow the code to print when the led if off.
NOTE: For other boards, make sure you know whether they are active low or active high. If the LED is active low (LED is on when led1 = 0), change the if statement to be:
if(led1){
Hope this helps!
-Karen, team Mbed
