7 years, 11 months ago.
uVision debugging issue with "Call Stack + Locals" and "System and Thread viewer"
Hi Team,
I am debugging mbed-os-example-ble\BLE_Button, the experience is not very good. I found the "Call Stack + Locals" is not updating correctly and "System and Thread viewer"(Debug\OS Support) is not updating at all.
How to solve this?
I am using uVision 5.24.2.0 to debug.
The steps I did to get uVision project file are: $ git clone https://github.com/ARMmbed/mbed-os-example-ble.git $ cd mbed-os-example-ble $ cd BLE_Button $ mbed deploy $ mbed compile -t ARM -m NRF52_DK $ mbed export -i uvision -m NRF52_DK
Thanks
Hi Cake,
The System and Thread Viewer in uVision doesn't have support for RTX5 yet as described here:
http://www.keil.com/support/man/docs/uv4/uv4_db_dbg_systhread_viewer.htm
As Mbed is built on RTX5 you won't be able to use it.
You can however make use of a RTX5 viewer description file and this will give you a custom view you may not have seen before. This is described here:
http://www.keil.com/support/man/docs/uv4/uv4_ca_manage_scvd.htm
From the Manage dialog you will want to add this file:
C:\Keil_v5\ARM\PACK\ARM\CMSIS\5.3.0\CMSIS\RTOS2\RTX\rtx5.scvd
Then when debugging under "View-Watch Windows" you will have a new option "RTX RTOS". Attached is a screen capture of a session we just ran with a ULINKpro with the BLE Button demo. We think this will help!
As for the Call Stacks and Locals pane, that isn't revealing much information probably because there isn't much of a call stack to show for those threads. Please contact Keil support if you have further questions about these views as they will know their limits/capabilities: http://www.keil.com/support/
-Ralph, Team Mbed
One current solution that I am aware of is Percepio's Tracealyzer: https://percepio.com/tz/keil-rtx5/ The Tracealyzer looks very shiny.
posted by 24 May 2018
