7 years, 11 months ago.
How to set LoRaWANInterface into class C mode
Hey folks,
I would like to know how can I put an mbed LoRaWANInterface as described here: https://os.mbed.com/docs/v5.8/reference/lorawan-api.html into Class C mode?
Thank you!
Cheers, Bruno
7 years, 10 months ago.
Call set_device_class() to switch classes. It's in the latest version of Mbed OS (5.8.4).
Thank you very much!
I already ran <<code>>mbed update mbed-os-5.8.4<</code>> in my project and thought that it was already on version 5.8.4, but it seems it was not. That's why I could not find the <<code>>set_device_class()<</code>> method. But after removing mbed-os library and adding it again, I was able to find the <<code>>set_device_class()<</code>> in my project and thought that it was already on version 5.8.4, but it seems it was not. That's why I could not find the <<code>>set_device_class()<</code>> method. But after removing mbed-os library and adding it again, I was able to find the <<code>>set_device_class()<</code>> method. But after removing mbed-os library and adding it again, I was able to find the <<code>>set_device_class()<</code>> method in the LoRaWANInterface class.
