7 years, 10 months ago.
build errors caused by " 'OnboardCellularInterface' does not name a type"
Hey all, I made a custom board that uses Cellular(ublox sara-u270, stm32f401vc). I made an "custom_targets.json" file for my custom board and confirmed that "mbed-os-example-blinky (use mbed-os 5.8)" works. I added the following element to the "custom_targets.json" file to run the example "https://os.mbed.com/docs/v5.8/reference/cellular-api.html".
custom_targets.json
"config": {
"modem_is_on_board": {
"help": "Value: Tells the build system that the modem is on-board as oppose to a plug-in shield/module.",
"value": 1,
"macro_name": "MODEM_ON_BOARD"
"modem_data_connection_type": {
"help": "Value: Defines how an on-board modem is wired up to the MCU, e.g., data connection can be a UART or USB and so forth.",
"value": 1,
"macro_name": "MODEM_ON_BOARD_UART"
I get these compile errors -> "error: 'OnboardCellularInterface' does not name a type"
Thanks for your help.
Hi Patrick,
Can you please provide us with your custom_targets.json file?
Thank you! - Jenny, team Mbed
posted by Jenny Plunkett 16 May 2018
