7 years, 11 months ago.
DISCO-F413ZH + X-NUCLEO-IKS01A2 Motion MEMS and Environmental Sensor
I recently got above hardware and going through the example on MBED5 here:
https://os.mbed.com/teams/ST/code/X_NUCLEO_IKS01A2/
The example code goes well partially, i can get readings through asynchronous calls, like get-xxx , etc.
However the interrupts assigned to D4, or D5 seems not being triggered, so that code does not work ? so far did not touch the board, or the header pins, same for the original code ?
do i miss something ? like enabling interrupts, pin assignments, board + header incompatibility, etc ?
Emilio
