7 years, 11 months ago.
Compile mbed using ubuntu 18.04
I'm recently update my laptop to ubuntu 18.04, but after that can't compile projects using GCC_ARM (latest arm-none-eabi). Someone has the same problem?
Thank you
7 years, 10 months ago.
Hi Santiago,
Can you please reply with the error output and information regarding your GCC_ARM_PATH in the Mbed CLI config and their version information? (i.e. arm-none-eabi version and Mbed CLI version)
- Jenny, team Mbed
Hi Jenny,
mbed version: 1.5.1 arm-none-eabi version : 6.3.1 20170620
error output when i tray to compile: /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: error: /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/crt0.o: Conflicting CPU architectures 13/1 /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: failed to merge target specific data of file /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/crt0.o
Thank you in advance!
posted by 14 May 2018
