7 years, 11 months ago.
mbed python error ...
.. could some kind person explain the following error that I am getting when trying to use mbed cli please ? File "/usr/local/lib/python3.5/dist-packages/mbed_cli-1.5.1-py3.5.egg/mbed/mbed.py", line 1191 sorted_scms = sorted(sorted_scms, key=lambda (m, _): not m) ^ SyntaxError: invalid syntax
7 years, 10 months ago.
Hi Andrew,
In order to use Mbed CLI you need to have Python 2.7+ installed. According to the Mbed CLI documentation, Python 3 is not compatible: https://github.com/armmbed/mbed-cli#requirements
- Jenny, team Mbed
Hello Andrew, I want to start looking into this, but need some extra info. Does this happen on all invocations or on a particular call? If a particular call, please let me know the command line you are trying to execute.
In addition, could you send me the following info. 1. Operation system: 2. python version (yes, I see that it is 3.5, but could you run 'python -V' to give me the exact release) 3. pip version (from pip -V)
Thank you, Earl
posted by Earl Manning 09 May 2018Hello Earl, Command: mbed import https://github.com/ARMmbed/mbed-os-example-blinky python -V Python2.7.12 python3 -V 3.5.2 pip -V 9.0.1 pip3 -V ... pip3 is not currently installed
posted by andrew eliasz 10 May 2018
