7 years, 11 months ago.
Reset target fail while CAN Bus connected
Hi
I am currently using CAN Bus with STM32 F446 RE
There is an other device on the bus broadcast CAN messages at 100 Hz600 Hz
The issue occur if I reset STM32 with BUS connected, a message on UART:
can ESR 0x0000.0000 + timeout status 0
appear and LED keep on blinking with specific pattern.
This will not occur if i reset the target with BUS unconnected.
I assume this as a problem with current mbed CAN Bus library, this issue occur back to Ver. 145
For earlier version although the UART message & LED keep silence, the acknowledge function will fail.
I'm looking for solution for this problem, the only method I use now is manually disconnect BUS to STM32 before power up.
The code I use is show as following:
TEST
#include "mbed.h" // Revision 166
CAN can2(D4, D10);
int main(){
can2.frequency(1000000);
while(1){
7 years, 10 months ago.
I try to remove the frequency change command from main() and try to set it at the declare stage.
This method work fine.
Modified
CAN can2(D4, D10, 1000000); //Set frequency at declaration
int main(){
//can2.frequency(1000000); //Avoid changing frequency when working
while(1){
Assigned to 7 years, 10 months ago.
