7 years, 11 months ago.
Error adding mbed-dev as library to project
Hi all,
I have tried many times to add mbed-dev to my project withou any success.
It's return an error. "Clone error"
Could you help me please ?
Thanks
Hi Nicola,
How are you adding mbed-dev to your project? With a URL or via the import wizard in the online compiler?
Also, I want to make sure you intend to create an Mbed OS 2 project instead of an Mbed OS 5 project? You can read about the differences here: https://os.mbed.com/docs/v5.8/tutorials/major-releases.html
- Jenny, team Mbed
Thanks for reply.
Same issues with the two ways, same error.
posted by Nicola Vincis 03 May 2018
Hi Nicola,
I have tried to import the mbed-dev library from the import wizard and with the following URL: https://os.mbed.com/users/mbed_official/code/mbed-dev/ - both options have timed out within the online compiler, but I am not receiving the "clone error" you are describing.
I will alert the web team of this issue, I suspect that the mbed-dev library is too large and the online compiler is timing out too soon before the library is completely imported. In the meantime, I have successfully imported the mbed-dev library by URL into a project via the offline Mbed CLI. You can view instructions on how to get started with the Mbed CLI here: https://os.mbed.com/docs/v5.8/tutorials/quick-start-offline.html
Once you have installed the Mbed CLI, you can add the mbed-dev library to your project with the following command: mbed add https://os.mbed.com/users/mbed_official/code/mbed-dev/
- Jenny, team Mbed
posted by Jenny Plunkett 03 May 2018
