7 years, 11 months ago.
I don't want to wait for the server response.
Quote:
I have modified 'setTxWait' to false at Line 107, but the 'time_used' is same when 'setTxWait' is true. How can I let my mDot send the data without waiting response?
ota_example.cpp
#include "dot_util.h"
#include "RadioEvent.h"
#include <sstream>
#if ACTIVE_EXAMPLE == OTA_EXAMPLE
static uint8_t network_id[] = { ... };
static uint8_t network_key[] = { ... };
static uint8_t frequency_sub_band = 1;
static lora::NetworkType public_network = lora::PUBLIC_LORAWAN;
static uint8_t join_delay = 5;
static uint8_t ack = 0;
static bool adr = false;
mDot* dot = NULL;
lora::ChannelPlan* plan = NULL;
AnalogIn CAin(PA_4);    //D10
AnalogIn CAout(PA_7);   //D11
float threshold_voltage = 0.5;
float sensorResultAin;
float sensorResultAout;
bool isAin_raise = false;
bool isAout_raise = false;
uint8_t In_counter = 0;
uint8_t Out_counter = 0;
Timer timer;
void counter()
    sensorResultAin = CAin.read(); //A in
    sensorResultAout = CAout.read(); //A out
    // logInfo("Ain %f, Aout %f",sensorResultAin, sensorResultAout);
    if(!isAin_raise && sensorResultAin > threshold_voltage)
        In_counter++, isAin_raise = true;
    else if(sensorResultAin < threshold_voltage - 0.2)
    if(!isAout_raise && sensorResultAout > threshold_voltage)
        Out_counter++, isAout_raise = true;
    else if(sensorResultAout < threshold_voltage - 0.2)
    wait_ms(50);
    plan = new lora::ChannelPlan_US915();
    assert(plan);
    dot = mDot::getInstance(plan);
    assert(dot);
    if (!dot->getStandbyFlag()) {
        logInfo("mbed-os library version: %d", MBED_LIBRARY_VERSION);
        // start from a well-known state
        logInfo("defaulting Dot configuration");
        dot->resetConfig();
        dot->resetNetworkSession();
        // make sure library logging is turned on
        dot->setLogLevel(mts::MTSLog::INFO_LEVEL);
        // update configuration if necessary
        if (dot->getJoinMode() != mDot::OTA) {
            logInfo("changing network join mode to OTA");
            if (dot->setJoinMode(mDot::OTA) != mDot::MDOT_OK) {
                logError("failed to set network join mode to OTA");
        // in OTA and AUTO_OTA join modes, the credentials can be passed to the library as a name and passphrase or an ID and KEY
        // only one method or the other should be used!
        // network ID = crc64(network name)
        // network KEY = cmac(network passphrase)
        // update_ota_config_name_phrase(network_name, network_passphrase, frequency_sub_band, public_network, ack);
        update_ota_config_id_key(network_id, network_key, frequency_sub_band, public_network, ack);
        // configure network link checks
        // network link checks are a good alternative to requiring the gateway to ACK every packet and should allow a single gateway to handle more Dots
        // check the link every count packets
        // declare the Dot disconnected after threshold failed link checks
        // for count = 3 and threshold = 5, the Dot will ask for a link check response every 5 packets and will consider the connection lost if it fails to receive 3 responses in a row
        // update_network_link_check_config(3, 5);
        // enable or disable Adaptive Data Rate
        dot->setAdr(adr);
        // Configure the join delay
        dot->setJoinDelay(join_delay);
        // Configure TxPower
        dot->setTxPower(20);
        // Configure LBT
        dot->setLbtTimeUs(5000);
        dot->setLbtThreshold(-80);
        // Configure TxDataRate
        dot->setTxDataRate(0);
        if (dot->setTxWait(false) != mDot::MDOT_OK)
            logError("Failed to set TxWait");
        // save changes to configuration
        logInfo("saving configuration");
        if (!dot->saveConfig()) {
            logError("failed to save configuration");
        // display configuration
        display_config();
    } else {
        // restore the saved session if the dot woke from deepsleep mode
        // useful to use with deepsleep because session info is otherwise lost when the dot enters deepsleep
        logInfo("restoring network session from NVM");
        dot->restoreNetworkSession();
    while (true) {
        // join network if not joined
        if (!dot->getNetworkJoinStatus()) {
            join_network();
        timer.start();
        counter();
        if(timer.read() > 15) {
            stringstream ss;
            string data_str;
            vector<uint8_t> tx_data;
            ss << (int)In_counter << "@" << (int)Out_counter;
            ss >> data_str;
            for (string::iterator it = data_str.begin(); it != data_str.end(); it++)
                tx_data.push_back((uint8_t) *it);
            logInfo("TxWait: %d", dot->getTxWait());
            logInfo("sending uplink with IN = %d, OUT = %d", In_counter, Out_counter);
            float time_used;
            time_used = timer.read();
            send_data(tx_data);
            time_used = timer.read() - time_used;
            logInfo("Time used: %fs", time_used);
            timer.reset();
#endif
MultiTech's official mbed team.
Modify the send_data function to call dot->send without blocking.
From mDot.h /**
  • Send data to the gateway
  • validates data size (based on spreading factor)
  • @param data a vector of up to 242 bytes (may be less based on spreading factor)
  • @returns MDOT_OK if packet was sent successfully (ACKs disabled), or if an ACK was received (ACKs enabled)
  • / int32_t send(const std::vector<uint8_t>& data, const bool& blocking = true, const bool& highBw = false);
