7 years, 11 months ago.
EthernetInterface errors while compiling with FRDM-K64F
Hello, I have tried a basic code for EthernetInterface from your cookbooks to start with ethernet communication with FRDM-K64F.
Ethernet
// Network interface
EthernetInterface net;
// Socket demo
// Set static IP
net.set_network("172.16.23.240", "255.255.255.0", "172.16.23.1");
// Bring up the ethernet interface
printf("Ethernet socket example\n");
net.connect();
// Show the network address
const char *ip = net.get_ip_address();
printf("IP address is: %s\n", ip ? ip : "No IP");
printf("MAC address is: %s\n", net.get_mac_address());
// Open a socket on the network interface, and create a TCP connection to mbed.org
TCPSocket socket;
socket.open(&net);
socket.connect("developer.mbed.org", 80);
// Send a simple http request
char sbuffer[] = "GET / HTTP/1.1\r\nHost: developer.mbed.org\r\n\r\n";
int scount = socket.send(sbuffer, sizeof sbuffer);
printf("sent %d [%.*s]\n", scount, strstr(sbuffer, "\r\n")-sbuffer, sbuffer);
// Recieve a simple http response and print out the response line
char rbuffer[64];
int rcount = socket.recv(rbuffer, sizeof rbuffer);
printf("recv %d [%.*s]\n", rcount, strstr(rbuffer, "\r\n")-rbuffer, rbuffer);
// Close the socket to return its memory and bring down the network interface
socket.close();
// Bring down the ethernet interface
net.disconnect();
printf("Done\n");
However a few compile errors occured:
Error: Identifier "socklen_t" is undefined in "EthernetInterface/Socket/Socket.h", Line: 66, Col: 59 Error: Incomplete type is not allowed in "EthernetInterface/Socket/Socket.h", Line: 101, Col: 21 Error: Incomplete type is not allowed in "EthernetInterface/Socket/Endpoint.h", Line: 59, Col: 25 Error: Identifier "SOCK_STREAM" is undefined in "EthernetInterface/Socket/TCPSocketServer.cpp", Line: 30, Col: 22 Error: Incomplete type is not allowed in "EthernetInterface/Socket/TCPSocketServer.cpp", Line: 33, Col: 25 Error: Identifier "AF_INET" is undefined in "EthernetInterface/Socket/TCPSocketServer.cpp", Line: 36, Col: 29 Error: Identifier "htons" is undefined in "EthernetInterface/Socket/TCPSocketServer.cpp", Line: 37, Col: 27 Error: Identifier "INADDR_ANY" is undefined in "EthernetInterface/Socket/TCPSocketServer.cpp", Line: 38, Col: 34 Error: Identifier "lwip_bind" is undefined in "EthernetInterface/Socket/TCPSocketServer.cpp", Line: 40, Col: 10 Error: Identifier "lwip_listen" is undefined in "EthernetInterface/Socket/TCPSocketServer.cpp", Line: 52, Col: 10 Error: Identifier "socklen_t" is undefined in "EthernetInterface/Socket/TCPSocketServer.cpp", Line: 70, Col: 6 Error: Identifier "lwip_accept" is undefined in "EthernetInterface/Socket/TCPSocketServer.cpp", Line: 71, Col: 15
No matter what code I use, this one or any template for FRDM-K64F with EthernetInterface, this compile errors appear.
I am using newest mbed-os ( 5.8.3 ) and newest EthernetInterface (rev. 54) including sub libraries.
Yes I did checked this thread: https://os.mbed.com/questions/5225/EthernetInterface-produces-compile-error/
Any suggestions?
Thank you.
Patrik Maraczek
Hi Patrik,
Perhaps something has gone wrong migrating an old project. Can you follow these steps using Mbed CLI and let us know how they work:
$ mbed new ethernet_test $ cd ethernet_test (place your source file into the ethernet_test folder) $ mbed ls ethernet_test ( revision in the current branch) `- mbed-os (#c05d72c3c005, tags: latest, mbed-os-5.8.3) $ mbed compile -m k64f -t arm
You should see this output:
Building project ethernet_test (K64F, ARM) Scan: . Scan: env Scan: mbed ... Compile [ 99.5%]: fsl_common.c Compile [ 99.8%]: patrik.cpp Compile [100.0%]: test_env.cpp Link: ethernet_test Elf2Bin: ethernet_test +------------------+--------+-------+-------+ | Module | .text | .data | .bss | +------------------+--------+-------+-------+ | [lib]\c_w.l | 13717 | 16 | 576 | | [lib]\cpprt_w.l | 42 | 0 | 0 | | [lib]\fz_wm.l | 18 | 0 | 0 | | [lib]\m_wm.l | 48 | 0 | 0 | | anon$$obj.o | 32 | 0 | 1024 | | mbed-os\drivers | 165 | 0 | 0 | | mbed-os\features | 52204 | 447 | 45827 | | mbed-os\hal | 1612 | 8 | 64 | | mbed-os\platform | 2548 | 89 | 412 | | mbed-os\rtos | 17477 | 2310 | 4592 | | mbed-os\targets | 12216 | 104 | 324 | | patrik.o | 492 | 0 | 76 | | Subtotals | 100571 | 2974 | 52895 | +------------------+--------+-------+-------+ Total Static RAM memory (data + bss): 55869 bytes Total Flash memory (text + data): 103545 bytes Image: .\BUILD\k64f\arm\ethernet_test.bin
-Ralph, Team Mbed
What do you mean with source file? The example i used above? Including EthernetInterface library?
posted by 04 May 2018I see his output with the example above without library:
C:\Users\Michal\ethernet_test>mbed ls
ethernet_test (None)
`- mbed-os (c05d72c3c005)
C:\Users\Michal\ethernet_test>mbed compile -m k64f -t arm
usage: make.py [-h] [-m MCU] [-t TOOLCHAIN] [--color] [--cflags CFLAGS]
[--asmflags ASMFLAGS] [--ldflags LDFLAGS] [-c]
[--profile PROFILE] [--app-config APP_CONFIG] [-p PROGRAM]
[-n PROGRAM] [-j JOBS] [-v] [--silent] [-D MACROS]
[-S [{matrix,toolchains,targets}]] [-f GENERAL_FILTER_REGEX]
[--stats-depth STATS_DEPTH] [--automated] [--host HOST_TEST]
[--extra EXTRA] [--peripherals PERIPHERALS]
[--dep DEPENDENCIES] [--source SOURCE_DIR]
[--duration DURATION] [--build BUILD_DIR] [-N ARTIFACT_NAME]
[-d DISK] [-s SERIAL] [-b BAUD] [-L] [--rpc] [--usb] [--dsp]
[--testlib] [--build-data BUILD_DATA] [-l LINKER_SCRIPT]
make.py: error: Could not find executable for ARM.
Currently set search path: No path set
[mbed] ERROR: "C:\Python27\python.exe" returned error code 2.
[mbed] ERROR: Command "C:\Python27\python.exe -u C:\Users\Michal\ethernet_test\mbed-os\tools\make.py -t arm -m k64f --source . --build .\BUILD\k64f\arm" in "C:\Users\Michal\ethernet_test"
I have never used Mbed CLI, there might be errors in settings.
posted by 04 May 2018Ok. I finally get it work using gcc_arm and source code from the example. And i got the same output result as yours:
Compile [ 99.8%]: fsl_common.c Compile [100.0%]: test_env.cpp Link: ethernet_test Elf2Bin: ethernet_test +------------------+--------+-------+-------+ | Module | .text | .data | .bss | +------------------+--------+-------+-------+ | [fill] | 215 | 8 | 2237 | | [lib]\c.a | 43529 | 2472 | 89 | | [lib]\gcc.a | 3336 | 0 | 0 | | [lib]\misc | 204 | 4 | 28 | | [lib]\nosys.a | 32 | 0 | 0 | | main.o | 574 | 0 | 76 | | mbed-os\drivers | 98 | 0 | 0 | | mbed-os\features | 46077 | 172 | 46072 | | mbed-os\hal | 1573 | 4 | 68 | | mbed-os\platform | 1891 | 260 | 21 | | mbed-os\rtos | 13593 | 168 | 6073 | | mbed-os\targets | 11121 | 12 | 384 | | Subtotals | 122243 | 3100 | 55048 | +------------------+--------+-------+-------+ Total Static RAM memory (data + bss): 58148 bytes Total Flash memory (text + data): 125343 bytes Image: .\BUILD\k64f\gcc_arm\ethernet_test.bin
Any suggestions what to do next?
(Sorry for the previous confused comments. Somehow cannot edit them or delete.)
posted by 04 May 2018Now that you have the project building you can add the "-f" option to have it flashed to the target for testing:
$ mbed compile -m k64f -t arm -f
A good tutorial on the CLI is available here and the official readme is on the project page: https://os.mbed.com/docs/v5.8/tutorials/quick-start-offline.html https://github.com/ARMmbed/mbed-cli
posted by 07 May 2018Flashing works, however, I am afraid I misunderstood your first answer. I used source code without ethernetinterface library. Now when compiling with library, fllowing errors appears using CLI:
Scan: FEATURE_STORAGE
Compile [ 0.2%]: Endpoint.cpp
[Warning] ip_addr.h@213,23: C++11 requires a space between string literal and macro [-Wc++11-compat]
[Warning] ip_addr.h@213,31: C++11 requires a space between string literal and macro [-Wc++11-compat]
[Warning] ip_addr.h@213,40: C++11 requires a space between string literal and macro [-Wc++11-compat]
[Warning] ip_addr.h@213,49: C++11 requires a space between string literal and macro [-Wc++11-compat]
[Error] _timeval.h@52,8: redefinition of 'struct timeval'
[ERROR] In file included from ./EthernetInterface/lwip/include/lwip/sockets.h:43:0,
from ./EthernetInterface/Socket/Socket.h:21,
from .\EthernetInterface\Socket\Endpoint.cpp:18:
./EthernetInterface/lwip/include/ipv4/lwip/ip_addr.h:213:23: warning: C++11 requires a space between string literal and macro [-Wc++11-compat]
LWIP_DEBUGF(debug, ("%"U16_F".%"U16_F".%"U16_F".%"U16_F, \
./EthernetInterface/lwip/include/ipv4/lwip/ip_addr.h:213:31: warning: C++11 requires a space between string literal and macro [-Wc++11-compat]
./EthernetInterface/lwip/include/ipv4/lwip/ip_addr.h:213:40: warning: C++11 requires a space between string literal and macro [-Wc++11-compat]
./EthernetInterface/lwip/include/ipv4/lwip/ip_addr.h:213:49: warning: C++11 requires a space between string literal and macro [-Wc++11-compat]
Errors are pointing to the EthernetInterface library, like it does using mbed online compiling.
Any suggestions?
Thank you
posted by 10 May 2018
