7 years, 11 months ago.
MBED Compatibility
Is this board model (Nucleo L452RE) supported by Mbed? When I launch the CLI program, it asks to connect the board on the USB. When I do the board lights up and starts running the blinky routine, but the CLI says "No Mbed device detected". Is there a COM port setting I'm missing here? Thanks,
THIS BOARD IS NOT AVAILABLE ON MBED
Hi Gene,
The NUCLEO-L452RE board is not currently supported on Mbed, so you won't be able to see it as an Mbed device when plugged into your computer. If you'd like to try adding the board to Mbed OS, you can take a look at the following resources:
- Jenny, team Mbed
