7 years, 11 months ago. This question has been closed. Reason: Off Topic
EFM32PG12_STK3402 - Expansion header Pin Naming is wrong
I found out that the pin names of the expansion header for the EFM32PG12_STK3402 is wrong. It is defined as:
Wrong Expansion header Pin Naming
EXP3 = PA8,
EXP4 = PC6,
EXP5 = PA9,
EXP6 = PC7,
EXP7 = PF3,
EXP8 = PC8,
EXP9 = PF4,
EXP10 = PC9,
EXP11 = PF5,
EXP12 = PA6,
EXP13 = PF6,
EXP14 = PA7,
EXP15 = PC11,
EXP16 = PC10,
But referencing to UG257: EFM32 Pearl Gecko PG12 Starter Kit User's Guide Chapter 4 it should be:
Correct Expansion header Pin Naming
EXP3 = PC9,
EXP4 = PA6,
EXP5 = PD9,
EXP6 = PA7,
EXP7 = PB6,
EXP8 = PA8,
EXP9 = PB7,
EXP10 = PA9
EXP11 = PB8,
EXP12 = PD10,
EXP13 = PD8,
EXP14 = PD11
EXP15 = PC11,
EXP16 = PC10,
