7 years, 12 months ago.
Compile Error in PortOut.h: Field _port has incomplete type port_t (aka port_s)
Good day,
I am starting out on a new project and have hit a wall trying to use PortOut. The code I'm trying to compile is as follows:
main.cpp
#define RGB_MASK 0x0200000A
#define RED_LED 0x02000000
#define GREEN_LED 0x00000008
#define BLUE_LED 0x00000002
PortOut rgb_led(Port0, RGB_MASK);
while(true){
wait(1);
rgb_led = RGB_MASK;
wait(1);
rgb_led = RED_LED;
wait(1);
rgb_led = GREEN_LED;
wait(1);
rgb_led = BLUE_LED;
wait(1);
When compiling, the following note and error appear:
Quote:
...\mbed\hal\port_api.h:32:16: note: forward declaration of 'port_t {aka struct port_s}'
and
Quote:
...\mbed\drivers/PortOut.h:109:12: error: field '_port' has incomplete type 'port_t {aka port_s}'
This is mbed code right out of the box. Am I doing something wrong?
Greetings, Andy
Hi there, which target/board are you using with this code?
- Jenny, team Mbed
posted by Jenny Plunkett 18 Apr 2018I am using the LPCXpresso1549 board.
posted by Andrew Delay 19 Apr 2018
