7 years, 11 months ago.
Output always showing -1000 degrees on nuleo F303K8
I tested my wires, sensor and set up on an arduino with a code that I found on the internet, and that works. However my Nucleo F303K8 always shows -1000 degrees C if I use this code, but also is if I use other codes on the internet.
Does anyone know a solution to this problem?
Kind regards, bjorntukkertje
