8 years ago.
Send float with Bluetooth not all values are sending
Hello when I send for example : float f = 0.123456789 On the other device I only receive 0.123457
The problem doesn't come from the other device. Beacause when I read the frames 6, 8 and 9 are missing.
Here my code
I have the same problem with : BT.printf(); BT.putc(); or BT.printf("%f", f);
8 years ago.
Hi there,
You are only receiving the number "0.123457" because your tostr method is only converting the first 6 decimal places of your float number into a string. Try the following to get all 9 digits of your number:
double f = 0.123456789; char buffer[32]; sprintf(buffer, "%.9lf", f); string sf(buffer); printf(sf.c_str());
- Jenny, team Mbed
