7 years, 12 months ago.
Using Multiple Thread?
Im using a module NXP 1781 and using SPI to access up to 8 x PCA9555 to have up to 80 x digital Outputs and Inputs. My solution uses Ethernet port to access a IHM as cliente TCP/IP. It hardware was used in other projects w/o problem, but, the developer used a desktop IDE and old mbed-rtos.
I created new Project and I need to create multiple Threads running in parallell. To minimize the I2C traphic I want to create a I2C comm thread to share communication with PCA9555 w/o need use sepalhore.
Other thread will be used to control communication between module and IHM over TCP/IP as Client.
The problem is that all Thread examples I used in my Project fails to work. It only Works individually into OnLine builder.
Do you have any suggestion?
Can I have 10 threads running in parallel? What I have to do to prevents overload in proccessing?
Regards.
Hi Jose,
Here's an example of 2 threads in Mbed OS, one in main() and the other in a separate function led2_thread(): https://os.mbed.com/docs/v5.8/reference/thread.html#thread-example
You can also explicitly create multiple Thread variables:
DigitalOut led1(LED1);
DigitalOut led2(LED2);
Thread thread1;
Thread thread2;
void led1_thread() {
while (true) {
led1 = !led1;
wait(0.5);
void led2_thread() {
while (true) {
led2 = !led2;
wait(1);
thread1.start(led1_thread);
thread2.start(led2_thread);
- Jenny, team Mbed
Thanks for your answer. I Firstly tryed it exactly example and in my case didnt Works. After working hard I Found the solution bellow at: https://www.embarcados.com.br/threads-no-mbed-os/
STEP 01: At Header File Defined stack size Local Buffers
unsigned char tcp_stk[2048]; unsigned char i2c_stk[1024];
STEP 02: At Header File Defined Threads using Priorityes(Normal) is save and Stack Size defined above
Thread thTCP_Comm(osPriorityNormal, 2048, &tcp_stk[0]);
Thread thI2C_Comm(osPriorityNormal, 1024, &i2c_stk[0]);
STEP 03:At Code Created threads pointing to Threads Entry
thTCP_Comm.start(TCP_CommThread);
thI2C_Comm.start(I2C_CommThread);
STEP 04:At Code Created threads
void TCP_CommThread(void *pvArgs)
Thread start code
while(1)
Thread loop code
void I2C_CommThread(void *pvArgs) {
Thread start code
Thread loop code
It is working w/o problem now!!!!!
By the way, thanks for your help!!!!!
posted by 30 Mar 2018
