8 years ago.
How to get FAT file metadata (modification time)?
I am using mBed 2.0 (MBED_LIBRARY_VERSION 93 to be exact) for writing and reading files from SD card.
How can I get the filestamp of an opened file?
Can I get the filename of the file, or is the path used only for opening it and then lost?
8 years ago.
Hi Jakub,
I would try using the readdir() function within the FATFileSystem: https://os.mbed.com/teams/mbed-official/code/FATFileSystem/file/28e685e5ff7f/FATDirHandle.cpp/
Here's a forum comment with code that may help: https://os.mbed.com/forum/mbed/topic/800/?page=1#comment-3926
- Jenny, team Mbed
Hi there,
Just to update the thread that I successfully managed to get the metadata. I didn't use the "readdir()" function from MBED though, but directly a "f_readdir()" that's used inside to get the structure called FILINFO, Here's the reference: http://elm-chan.org/fsw/ff/doc/sfileinfo.html and http://elm-chan.org/fsw/ff/doc/readdir.html
Thanks for pointing me into the right direction!
posted by Jakub K 03 Apr 2018
