8 years ago.
Operating temperature range of LPC1768
May I know what is the operating temperature range of LPC1768?
8 years ago.
Hi there,
The minimum operating temperature of the LPC1768 is -40°C and the maximum operating temperature is +85°C.
I found this information here: https://www.mouser.com/NXP-Semiconductors/Semiconductors/Embedded-Processors-Controllers/Microcontrollers-MCU/ARM-Microcontrollers-MCU/_/N-6hpef?keyword=LPC1768&P=1z0jm4m
- Jenny, team Mbed
If you are asking for LPC1768 microcontroller itself, answer is above explanation but Mbed LPC1768 module is different.
For example, I can see ASE-12-D-C-T & ASE-50-D-C-T, Xtal OSC on the schematics.
https://abracon.com/Oscillators/ASEseries.pdf
Those are -10°C to +60°C operating temperature.
We cannot judge the operating temperature via each components specification but this is design concept issue.
We need to get the answer from NXP.
The flyer says "Rapid prototyping board".
I can imagine the operating range is more smaller range.
8 years ago.
You can find part specifications for LPC MCUs (and Kinetis) at nxp.com ... look under the Product menu. Here's ashortcut: https://www.nxp.com/products/processors-and-microcontrollers/arm-based-processors-and-mcus:ARM-ARCHITECTURE
The Mbed LPC1768 was actually designed by Arm :)
The operating range for the board should be assumed to be 0 to 70 degrees. It is intended for development purposes rather than deployment in end applications.
