8 years ago.
Mbed CLI does not support ARM_MPS2 offline, but the online compiler supports it
I'm trying to use the blinky example. It works with the binary compiled by online compiler. However the export feature does not work, so i try to use the Mbed CLI to export the code.
But when im using Mbed detect, it says no supported toolchain. And when i use Mbed compile, it says ARM_MPS2 is not a supported MCU.
Is this normal?
Thank you!
