8 years ago.
Can't get "mbed test" to run on Nucle-L476rg - sync failed
I'd like to setup a simple test, but my board does not seem to respond to the sync with mbedgt over the serial port.
Here's what I did:
mbed new test_project
cd test_projet
mbed new library my_lib
mkdir -p my_lib/TESTS/TestGroup1/TestCase1
add a test in my_lib/TESTS/TestGroup1/TestCase1/main.cpp
copy paste test example from https://os.mbed.com/docs/v5.7/tools/testing-applications.html
mbed test -m NUCLEO_L476RG -t GCC_ARM compile
mbed test -m NUCLEO_L476RG -t GCC_ARM run -n my_lib-tests-testgroup1-testcase1 -v
It seems the device does not respond to the sync messages from mbedht? How to solve this?
Output (relevant snippet):
mbedgt: mbed-host-test-runner: started
[1521458165.38][HTST][INF] host test executor ver. 1.3.1
[1521458165.38][HTST][INF] copy image onto target...
[1521458165.38][COPY][INF] Waiting up to 60 sec for '07650221623165685D75F330' mount point (current is '/Volumes/NODE_L476RG')...
cp: /Volumes/NODE_L476RG/TestCase1.bin: Is a directory
[1521458165.92][COPY][ERR] [ret=1] Command: ['cp', 'BUILD/tests/NUCLEO_L476RG/GCC_ARM/my_lib/TESTS/TestGroup1/TestCase1/TestCase1.bin', '/Volumes/NODE_L476RG/TestCase1.bin']
[1521458169.92][COPY][INF] Waiting up to 60 sec for '07650221623165685D75F330' mount point (current is '/Volumes/NODE_L476RG')...
[1521458182.90][HTST][INF] starting host test process...
[1521458182.90][CONN][INF] starting connection process...
[1521458182.90][CONN][INF] notify event queue about extra 60 sec timeout for serial port pooling
[1521458182.90][CONN][INF] initializing serial port listener...
[1521458182.90][PLGN][INF] Waiting up to 60 sec for '07650221623165685D75F330' serial port (current is '/dev/tty.usbmodem143233')...
[1521458182.90][HTST][INF] setting timeout to: 60 sec
[1521458183.53][SERI][INF] serial(port=/dev/tty.usbmodem143233, baudrate=9600, read_timeout=0.01, write_timeout=5)
[1521458183.53][SERI][INF] reset device using 'default' plugin...
[1521458183.93][SERI][INF] waiting 1.00 sec after reset
[1521458184.93][SERI][INF] wait for it...
[1521458184.93][SERI][TXD] mbedmbedmbedmbedmbedmbedmbedmbedmbedmbed
[1521458184.93][CONN][INF] sending up to 5 sync packets (specified with sync=5)
[1521458184.93][CONN][INF] sending preamble '8346530a-5034-4032-8d3f-ab4ac149fffe'
[1521458184.93][SERI][TXD] notify_sync_failed event
[1521458204.97][HTST][INF] exit_event_queue received
[1521458204.97][HTST][INF] test suite run finished after 22.07 sec...
[1521458204.98][HTST][INF] CONN exited with code: 0
[1521458204.98][HTST][INF] No events in queue
[1521458204.98][HTST][INF] host test result() call skipped, received: sync_failed
[1521458204.98][HTST][WRN] missing exit event from DUT
[1521458204.98][HTST][INF] calling blocking teardown()
[1521458204.98][HTST][INF] teardown() finished
[1521458189.94][CONN][INF] resending new preamble 'aedd0c4f-f4df-4707-bab6-7192dd3c1fd2' after 5.00 sec
[1521458189.94][SERI][TXD]
[1521458194.94][CONN][INF] resending new preamble '91c19156-0656-4047-ac89-7c82e6afc109' after 5.01 sec
[1521458194.94][SERI][TXD]
[1521458199.95][CONN][INF] resending new preamble 'c79ff6bc-7e33-478b-a22b-d31edd8aad7c' after 5.01 sec
[1521458199.95][SERI][TXD]
[1521458204.96][CONN][INF] resending new preamble 'b5ff5f6a-fb93-4a0c-a0da-ea3c91d0126c' after 5.00 sec
[1521458204.96][SERI][TXD]
[1521458204.97][HTST][ERR] None
[1521458204.97][HTST][WRN] stopped to consume events due to
