8 years ago.
DAC definitions on STM32F103
I'm trying to use the DAC on the ATM32F103, but it seems the declaration files are not included.
I have written the code below to initialize it:
DAC INIT
// Initialize the DAC
 DAC->CR |= ((7ul << 19));                                    // Software trigger sets DAC CH2
 DAC->CR &= ~ ((1ul << 18));                              // Trigger disabled. write to DAC_DHRx Register
 DAC->CR &= ~ ((1ul << 17));                              // Enable DAC Output buffer
 DAC->CR |= ((1ul << 16));                                    // Enable DAC Channel 2*/
 DAC->CR |= ((7ul << 3));                                       // Software trigger sets DAC CH1
 DAC->CR &= ~ ((1ul << 2));                                // Trigger disabled. write to DAC_DHRx Register
 DAC->CR &= ~ ((1ul << 1));                                // Enable DAC Output buffer
 DAC->CR |= ((1ul << 0));                                      // Enable DAC Channel 1
The code doesn't compile, and the following error is shown: Error: Identifier "DAC" is undefined in "main.cpp", Line: 145, Col: 3
Any ideas?
