8 years, 1 month ago.
The compiler displays Error 247 but I don't know why
Hi everyone!
I'm currently working on a program for a school project and the compiler displays an error 247 (variable or function already define) for several objects, but I can't find where the multiples definitions are from. Perhaps somebody can help me :)
Here's my code (so far) :
This file contains my functions
#include "options.h"
DigitalIn freq1(p8);
Timer timer;
float compteur()
float T=0;
if(freq1==1)
timer.start();
if(freq1==1)
T = timer.read();
wait(1);
timer.stop();
timer.reset();
return T;
float frequence(float periode)
{ int f;
f = (1/periode);
return f;
int receive(Serial pc)
{ int data[5];
pc.scanf("%d", data);
pc.printf("%d", data);
return 0;
int transmit(int retour) {
int n=11;
int a;
int c = 0 ;
while( n >= 1 ) {
a = n % 2;
if ( a == 1 ) {
c = c + 1;
n = n / 2;
return 0;
This one is the main
Serial in(p9, p10);
Serial pc(USBTX, USBRX);
Serial out(p13, p14);
pc.format(7, Serial::Even, 1);
pc.baud(9600);
in.format(7, Serial::Even, 1);
in.baud(9600);
out.format(8, Serial::Even, 1);
out.baud(9600);
And finally this one is my header file
#ifndef OPTIONS_H_INCLUDED #define OPTIONS_H_INCLUDED #include "mbed.h" #include "compt.cpp" float frequence(float); int receive(Serial); #endif
8 years ago.
Hi Victor,
For which target/board are you trying to compile for? Also, in your last header file, on line 5 #include "compt.cpp" that code is going to essentially copy all of the contents from your compt.cpp file into your header file, which may be causing the multiple definitions.
- Jenny, team Mbed
