8 years, 1 month ago.
USBSerial problems
on LPC1768 I'm playing with the USBSerial class.
Why does the below not work. When I send characters to the USBserial port from a terminal the first one gets printed out and then the MCU crashes?
Is it something obvious I am missing?
main
#include "USBSerial.h"
#include "SerialCMDParser.h"
DigitalOut myled(LED1);
USBSerial ser;
SerialCMDParser serCMDParser(ser);
        printf("testing usb serial\r\n");
        myled=!myled;
        wait(1);
SerialCMDParser.h
#ifndef _SERCMDPARSER_H_
#define _SERCMDPARSER_H_
class SerialCMDParser
private:
    USBSerial &_ser;
     void _Read(void);
public:
    SerialCMDParser(USBSerial &ser);
#endif
SerialCMDParser.cpp
SerialCMDParser::SerialCMDParser(USBSerial &ser)
:_ser(ser)
    _ser.printf("starting...\n\r");
    _ser.attach(this, &SerialCMDParser::_Read);
void SerialCMDParser::_Read(void){
    printf("reading\r\n");
    while(_ser.readable())
       char c = _ser.getc();
       _ser.putc(c);
Some ideas. First, don't use printf in ISR context. So comment out that line in _Read();
https://os.mbed.com/docs/v5.7/reference/mutex.html
USB device can be kind of big make sure main stack is large enough. When mbed dies it usually prints out a message telling you why. I take it you are not seeing any messages on the terminal? You have to make sure the NDEBUG macro is not defined to see messages I think.
I've had issues if I hit the USB serial receive routine too fast. I would make sure you are not sending characters too fast and focus on getting in and getting out of the ISR. I think if you are inside the ISR and another char is received it can cause issues. I would avoid the call to _ser.puc(c) from inside ISR. Instead put characters into a shared volatile buffer and then read them out during normal program flow. There is a circular buffer class inside mbed that's pretty good for this as you can simply keep pushing chars into it.
volatile CircularBuffer<char, kBufferSize> usb_buffer;
Where are you getting this USBSerial class from? I don't think it is part of regular mbed-os. Is this under /features/unsupported? I wonder if "unsupported" is a hint...
https://github.com/ARMmbed/mbed-os/tree/master/features/unsupported/USBDevice
posted by Graham S. 11 Mar 2018
