8 years ago.
FRDMK64
hello Sirs
I am using Freedom Board K64, And here is my question is to s=design a module called MeasurePulse which uses the Flex Timer module and can be called from a main program to detect and measure the duration of an pulse input to the microcontroller system. In my design I need to indicate the length of pulse that can be measured and any restrictions on the type of input pulse.
I have done some work accordingly, and I figured out that I need to use the felxTime rmodule, I am using two channels FTM0 and FTM1.
Hi Ayman,
Do you have a specific question?
- Jenny, team Mbed
posted by Jenny Plunkett 23 Mar 2018
