8 years, 1 month ago.
CAN not working on nucleof446RE
hello
i would like to use CAN BUS for a project, in order to do this, first i tried to use example code provided in mbed library but...nothing... both of RX and TX CAN pin are pulled up to +5V, that is all... anyone have an idea ? or i forgot something ? i use nucleo F446RE
here is the code i used
Thanks
Ticker ticker;
DigitalOut led1(LED1);
DigitalOut led2(LED2);
CAN can1(PA_11, PA_12);
CAN can2(PB_5, PB_6);
char counter = 0;
void send() {
printf("send()\n");
if (can1.write(CANMessage(1337, &counter, 1))) {
printf("wloop()\n");
counter++;
printf("Message sent: %d\n", counter);
wait(0.2);
led1 = !led1;
printf("main()\n");
ticker.attach(&send, 1);
CANMessage msg;
printf("loop()\n");
if (can2.read(msg)) {
printf("Message received: %d\n", msg.data[0]);
led2 = !led2;
Hello Olivier,
- The code is OK. It's running fine on my NUCLEO-F446RE.
However, I'd suggest to removeprintf("loop()\n");in order not to overload the serial terminal on your PC. - Make sure you are using CAN tranceivers (like MCP2551 or TJA1040, or etc.) for the communication over the CAN bus (see the links below how).
Some links that could be of help:
https://os.mbed.com/users/WiredHome/notebook/can---getting-started/
https://os.mbed.com/handbook/CAN
https://os.mbed.com/users/hudakz/code/CAN_Hello/
( https://os.mbed.com/users/hudakz/code/CANnucleo_Hello/ )
