10 years, 10 months ago.
CC3000 failing with K64F
I am using the CC3000 with K64F and this library. I've been able to get it working pretty easily but another problem is three CC3000 modules of mine are dead now. I'm not sure what's going wrong. Here are the pin mappings that I used:
Pin name CC3000 SPI name Pin Name Pin on K64F
Vcc (Vin) - P5V_USB J3 10
GND - GND J2 14
INT SPI1_PCS0 PTD4 J6 04
EN I2C0_SDA PTC9 J1 09
CS SPI0_PCS0 PTD0 J2 06
MOSI SPI0_MOSI PTD2 J2 08
MISO SPI0_MISO PTD3 J2 10
SCK SPI0_SCK PTD1 J2 12
Is there something wrong with my connections? Again, the modules do work correctly for some time but then they stop working. Thanks in advance!
Do you have a CC3000 board which includes its own voltage regulator? Because I don't think the CC3000 itself can survive 5V supply.
We are using the adafruit board and I'm pretty sure this should have a voltage regulator: https://www.adafruit.com/products/1469
When I say that it stopped working I mean that it can't even complete wifi.init() successfully.
posted by 06 May 2015Indeed, voltage regulator should be on board there. Then I wouldn't know why it breaks.
posted by 06 May 2015Also, I was powering a neo pixel LED strip of length 300 without using an external power supply (not all of them were on at any time). Could this have caused a problem?
posted by 07 May 2015Well the CC3000 + K64F is already quite low on a regular USB supply. (500mA). With LED strip added it would not be sufficient. So it depends a bit on what you used as supply. However too little voltage should not cause damage to the CC3000. Without sufficient decoupling on the LED strip you could possibly generate voltage spikes which could damage it. But it is questionable if that would be the cause.
They jsut stopped working ?
posted by Martin Kojtal 04 May 2015
