8 years, 1 month ago.
Problem exporting to eclipse (--source option seems to be ignored) using mbed-cli
I am compiling multiple binaries in a mbed-cli environment using multiple source locations using the following command: mbed compile -m NUCLEO_L432KC -t GCC_ARM profile debug source mbed-os source project\blinky This works fine
When I try to export it to Eclipse for debugging no Eclipse project files are generated (which I can find)
mbed export -i eclipse_gcc_arm -m NUCLEO_L432KC profile debug source mbed-os source project\blinky
From what I found in the documentation this should work. Has anyone a workaround or is my assumption that this should work incorrect?
Arjan
