12 years, 11 months ago.
how high is the max current on DigitalOut?
hey guys,
i will 4 Led´s connected on PIN17, 18 19 and 20 as DigitalOut.
one LED had 20mA. is that possible? or i need a mosfet?
thanks for your answers
40mA each digital out. You will have no problems without a FET. You need to limit the current through the led.
Vs-Vdrop/ 16 mA will work your resistor value out.
All you need to know can be found here https://mbed.org/handbook/mbed-NXP-LPC1768 (assuming you are using 1768)
posted by 08 Apr 201312 years, 11 months ago.
From the handbook:
Quote:
Digital IO pins are 3.3v, 4mA each, 400mA max total
The 40 mA (at high level -45 mA) is the 'short circuit' current and not the constant current. You might stretch it a bit, I have done 20 mA on the I2S output without problems but no guarantees.. Better put a FET in.
