8 years, 2 months ago.
BLDC ESC Motor
My BLDC motor is working with the new ESC. Earlier it used to beep with the older ESC, but now it doesn't even beeps nor does the motor starts. What could be problem? Is the motor damaged or is there any other issues?
  • The code is perfectly fine and the connections are also correct with proper voltage supply.
