8 years, 1 month ago.
mbed-os-example-ble-Button not working
I'm using the plataform Ublox EVK Nina B1 and I add the code to compile and get the .hex, but my problem is when I try to conect with my android the bluetooth signal disappear. If I press the reset button the signal can back for a short time and disappear again.
Can you help me?
Thanks for your attetion.
Best Regards
Rhenan
could you please tell me the steps , what you did exactly?
posted by vani N 24 Dec 2018
7 years, 3 months ago.
While compile the application getting "[Fatal Error] main.cpp@23,21: ble/BLE.h: No such file or directory [ERROR] .\main.cpp:23:21: fatal error: ble/BLE.h: No such file or directory
  1. include "ble/BLE.h" ^ compilation terminated." error.
could you please help anyone?
Thanks
Hi Vani,
What board do you use? Are you using mbed-os-example-ble-Button?
posted by Desmond Chen 20 Dec 2018
Hi Desmond Chen,
I am using CY8CKIT_062_BLE board. Yes i am using mbed-os-example-ble-Button application.
7 years, 2 months ago.
Hi Vani,
This because the "BLE" feature doesn't add to this target correctly, please add the follow configuration to your mbed_app.json.
Assume your are using target FUTURE_SEQUANA
mbed_app.json
    "config": {
        "ble_button_pin_name": {
            "help": "The pin name used as button in this application",
            "macro_name": "BLE_BUTTON_PIN_NAME",
            "required": true
    "target_overrides": {
        "FUTURE_SEQUANA": {
            "target.features_add": ["BLE"],
            "ble_button_pin_name": "USER_BUTTON"
Thanks,
- Desmond, team Mbed
