8 years, 1 month ago.
Add new mbed config parameter
Hello everyone,
I would like to add a new mbed config parameter and access it afterwards, but I can't seem to find where the config (".mbed" file) is parsed. I already tried to add it like the compiler paths (i.e. GCC_ARM_PATH etc.) in the settings.py file, but this does not work since the new parameter is not listed as environment variable. So how can this be done?
Oliver,
You should use the mbed config command. For details see 'mbed config -h'. Or you can add configurations to the config.json file.
-Austin
