8 years, 2 months ago.
mDot persistent variables across sleep
Hello everyone –
Does anyone have example code that they can share showing the use of read and write user backup register? I can’t get it to work right.
This isn't working for me:
                    if ((ret = dot->writeUserBackupRegister(0, sleeptime)) != mDot::MDOT_OK){
                            pc.printf("Failed to write sleeptime\r\n");
                        } else {
                            pc.printf("Wrote sleeptime\r\n");
I’m trying to save my sleep time of dot->sleep(sleep_time, mDot::RTC_ALARM); between sleeps.
I think it is working although your check fails because it is expecting MDOT_OK to be returned.
MDOT_OK is defined as 0 and is equivalent to false. The check is printing failed if NOT 0 is returned. In the success case true will be returned which is definitely not 0.
From mDot.h the backup register functions are declared to return a true or false value https://os.mbed.com/teams/MultiTech/code/libmDot-mbed5/file/mDot.h/
bool writeUserBackupRegister(uint32_t reg, uint32_t data); bool readUserBackupRegister(uint32_t reg, uint32_t& data);
