8 years, 2 months ago.
BLDC motor
The BLDC motor is not running after the first successful run. It creates the initial beep sound and then it doesn't rotates. What might be the issue and how to correct it. I am using NUCLEO-F767ZI board. The control pin of the motor is connected to the PWM pin of the board, the red wire is not connected and the ground to the ground. The thick red and black wire of the ESC are connected to 8V DC power supply.
