8 years, 2 months ago.
ESP8266 - Respond to a HTTP POST Request from a webpage
Hi guys,
At the moment I have written an application running on an STM32F411RE which uses an ESP8266 to serve a configuration webpage to a browser. Currently the user can enter information into the form and submit it. The data from the form reaches the ESP8266 and STM32F411RE as expected which I then parse and send back a HTTP OK response e.g.
#define ESP8266_HTTP_OK "HTTP/1.1 200 OK\r\n"
This response is reaching the browser (verified with the debugger in Google Chrome) however when I send the HTML page back to the browser nothing seems to happen.
In my serveBuffer() function I have hard coded the connection parameter to the 0th connection which may cause issues. Here is the implementation:
int serveBuffer(const char* bufferToSend, int len){
int ret = ESP8266_FAIL_NO_GOOD_RESPONSE;
int offset = 0;
char recv[255] = {0};
char serialBuffer[255] = {0};
bool readyToSend = false;
esp.printf("AT+CIPSEND=0,%d\r\n", len);
readResponse(recv, sizeof(recv), 1);
for(int i = 0; ((i < sizeof(recv)) && readyToSend == false); i++){
if(recv[i] == '>'){
readyToSend = true;
if(readyToSend){
while(len > 0){
strncpy(serialBuffer, &bufferToSend[offset], sizeof(serialBuffer));
esp.printf("%s", serialBuffer);
offset += strlen(serialBuffer);
len -= (strlen(serialBuffer) + 1);
memset(serialBuffer, '\0', sizeof(serialBuffer));
pc.printf("\n");
ret = readResponse(recv, sizeof(recv), 1);
return ret;
Here is how I'm currently handling the request:
int handleClientWebRequest(){
char buffer[255] = {0};
char numBuf[4] = {0};
int ret;
//... other data vars
readResponse(buffer, sizeof(buffer), 1);
if(strstr(buffer, "GET")){
ret = ESP8266_RECV_REQUEST;
else if(strstr(buffer, HOUR_KEY)){
//parse fields
ret = ESP8266_ALARM_REQUEST;
serveBuffer(ESP8266_HTTP_OK, strlen(ESP8266_HTTP_OK));
serveBuffer(CONFIG_PAGE, strlen(CONFIG_PAGE));
closeConnection();
else{
ret = ESP8266_NO_REQUEST;
return ret;
Then only way I can get the config page back after a submit is to close down the browser tab and re-request the page. Are these steps correct or should I try to handle it in a different manner?
Any assistance with this would be much appreciated!
Thanks, Russell Bateman
