8 years, 2 months ago.
Eventqueue
I'm using nrf52 and the Mbed-os-EddystoneService exemple, in this exemple there is 3 frames (URL-TLM-UID) sended by the device when it was in beacon mode. You can see the 3 frames after 30 sec. I added another frame that i called " iBeacon Frame" and you can see that there are 4 frames sended after 30 sec. Everythink work normarly but if i turn off and turn on my device. The frames will not be sended.
I tried to add led at the first of different function and i saw that every time the code stopped at Eventqueue function.
Thank you for your help.
Zakaria.
The problem was with the version of mbed os. I did an update of mbed os and everythink work normaly.
posted by Zakaria AIT BOUALI 18 Jan 2018
