8 years, 3 months ago.
RZ/A1 support
When will the GR-PEACH board for the Renesas RZ/A1H be supported? I tried a simple example and it wont even compile online.
Thanks,
Thomas
Mbed OS 5.7.2 support GR-PEACH board.
https://github.com/ARMmbed/mbed-os/pull/5628
Mbed OS examples will be updated shortly, but you can also update the mbed-os library in your code from online compiler. There's revision button on the top tab in the online compiler. Select the mbed-os library, click on the revision and check if the mbed-os lib is using the latest revision.
