8 years, 2 months ago.
compiler doesn't work anymore, after the 5.7.2 release
HELP !!! Since totay evening the compiler doesn't work anymore. When I press the "compile"-Button the compiler-dialog-box appears but the compiler will never end, i.e. the status is always "initializing".
I strongly assume this problem is with the release of Mbed OS 5.7.2 !! regards David
Sorry for the downtime, I can confirm we suffered an outage of the online compiler last night at around 19:45 UTC. This was caused by disk space issues and was resolved by 20:10 UTC.
We're monitoring the disk space issue and exploring options for migrating to a larger disk/server. The release of Mbed OS 5.7.2 had no effect, other than perhaps temporarily increasing site usage.
Hi James,
I'm using nrf52 and the Mbed-os-EddystoneService exemple, in this exemple there is 3 frames (URL-TLM-UID) sended by the device when it was in beacon mode. You can see the 3 frames after 30 sec. I added another frame that i called " iBeacon Frame" and you can see that there are 4 frames sended after 30 sec. Everythink work normarly but if i turn off and turn on my device. The frames will not be sended.
I tried to add led at the first of different function and using printf function, i saw that every time the code stopped after the excution of the Eventqueue function. for working i have to download the program again.
Thank you for your help.
Zakaria.
posted by 10 Jan 20188 years, 2 months ago.
same problem in my case only one works one hour before, now infinite initializing...
