8 years, 3 months ago.
Confusion about PwnOut class
I am super confused how the pwm class works.
The first program is from the PwmOut referance file:
LED_Fade
// Fade a led on.
PwmOut led(LED1);
        led = led + 0.01;
        wait(0.2);
        if(led == 1.0) {
            led = 0;
Base o the previous example I wrote this next program, that should act similar to the previous program, but for some reason it is backwards (adding to led dims LED1, subtracting from led brightens LED 1):
Control LED brightness using keyboard
//Author: collinan
//Control LED brightness using keyboard
//Tested on FRDM-KL46Z (using Terminal, on MacBook pro)
//'u' for brightness up
//'d' for brightness down
//Program compiles
Serial pc(USBTX , USBRX);//tx, rx
PwmOut led(LED1);
    led=0;
    while (1) {
        pc.printf("Press 'u' to brighten LED1, and 'd' to dim LED1 \n\r");
        char c = pc.getc();//get user input
        //this "if" should brighten but it dims LED
        if((c == 'u')) {
            pc.printf("IN Bright\n\r");
            if(led!=1) {
                led =led + 0.1;
            } else {
                pc.printf("Max reached.\n\r");
        //this "if" should dim but it brightens LED
        if((c == 'd') ) {
            pc.printf("IN Dim\n\r");
            if(led!=0) {
                led =led - 0.1;
            } else {
                pc.printf("Min reached.\n\r");
Any explanation wold be appreciated. Thanks in Advance.
