8 years, 2 months ago.
HTML web server response restricted
Can you help? i am using DISCO_L475VG_IOT01-wifi_http_server example.
My response is limited to 1515 and if i go any higher STM32L4 will crash. ret = WIFI_SendData(0, (uint8_t *)http, 1515, &SentDataLength, WIFI_WRITE_TIMEOUT);
Thanks!
Where do you allocate the http buffer? Is it big enough? The default web server example uses 1024 byte buffers, so you'd need to increase those.
Hi, I have change it to 3072 so it should be ok. and it is on beginning and static.
posted by Joni Patana 19 Dec 2017
I have also try to change ES_WIFI_DATA_SIZE on Wifi files and also direcly CMD size but that one is not helping ether.
