8 years, 4 months ago.
Communicating with Raspberry Pi Sense Hat
Is it possible to communicate between the STM32F746 Nucleo-144 and the Raspberry Pi Sense Hat using the input/output pins, or is the Sense Hat only compatible with the Raspberry Pi itself?
Assuming Sense Hat provides GPIO like Serial or I2C, then you should be able to communicate over that protocol. Here are some examples on the mbed side:
https://os.mbed.com/docs/v5.6/reference/serial.html https://os.mbed.com/docs/v5.6/reference/i2c.html
You'll need to find the equivalent code for the Raspberry pi to run to communicate over these.
