8 years, 3 months ago.
Sleep and deepsleep modes work differently on two equal boards
Greetings I am testing the different operating modes of a NUCLEOL476RG board with a code example. This code puts the microcontroller in the different operating modes it has in order to be able to measure (using jumper JP6) the current it consumes in each mode. The problem is that I have several boards (3) and for each I measure completely different current values. To illustrate these here are the values that I get:
Expected consumption: stop1 = 6.6uA stop2 = 1.1-1.4 uA (RTC on).
Board 1: stop1 = 6.6uA stop2 = 1.4uA.
Board2: stop1 = 82uA stop2 = 82uA.
Board3: stop1= 2uA Stop2 = 2uA.
the code used is this and I used mbed-dev library instead of common mbed.h (this code can be consulted in the following link https://os.mbed.com/teams/ST/code/Nucleo_sleep/file/cef094cd4cfa/main.cpp):
InterruptIn event(USER_BUTTON);
DigitalOut myled(LED1);
int go_to_sleep = 0;
void pressed()
printf("Button pressed\n");
go_to_sleep = go_to_sleep + 1;
if (go_to_sleep > 3) go_to_sleep = 0;
int i = 0;
printf("\nPress Button to enter/exit sleep & deepsleep\n");
event.fall(&pressed);
while (1) {
if ((go_to_sleep == 0) || (go_to_sleep == 2)) {
printf("%d: Running\n", i);
myled = 1;
wait(1.0);
if (go_to_sleep == 1) {
myled = 0;
printf("%d: Entering sleep (press user button to resume)\n", i);
wait(0.1); // To let the printf finish
sleep();
if (go_to_sleep == 3) {
myled = 0;
printf("%d: Entering deepsleep (press user button to resume)\n", i);
deepsleep();
i++;
I have tested these boards using SW4TStm32 and with all three I get the expected values instead of generated with mbed.
I used the board2 to test the consumption in shutdownmode (0,4uA) programming code with mbed mixing with HAL so I assume therefore that some register prevents board 2 going into deepsleep (and in sleep) and that register is not deleted correctly when reprograming with mbed.
//#include "WakeUp.h"#include "STM32L4xx_HAL_Driver.h"
#include <ctype.h>
Serial PC(D1, D0);
bool habilitado;
void pressed()
if (go_to_sleep > 5) go_to_sleep = 0;
if(go_to_sleep==5){
HAL_PWR_DisableWakeUpPin(PWR_WAKEUP_PIN2);
__HAL_PWR_CLEAR_FLAG(PWR_FLAG_WUF2);
HAL_PWR_EnableWakeUpPin(PWR_WAKEUP_PIN2_LOW);
HAL_Init();
SystemClock_Config();
//PC.baud(19200);
int i = 0;
PC.printf("\nPress Button to enter/exit sleep & deepsleep\n");
__HAL_RCC_PWR_CLK_ENABLE();
HAL_PWR_EnableBkUpAccess();
if (READ_REG(RTC->BKP31R) == 1)
WRITE_REG( RTC->BKP31R, 0x0 );
if (__HAL_PWR_GET_FLAG(PWR_FLAG_WUF2) != RESET)
/* Initialize the User push-button to generate external interrupts */
while (1) {
if ((go_to_sleep == 0) || (go_to_sleep == 2)||(go_to_sleep==4)) {
PC.printf("\n\r%d: Running\n", i);
myled = 1;
wait(1.0);
myled = 0;
PC.printf("%d: Entering sleep (press user button to resume)\n", i);
sleep();
myled = 0;
PC.printf("\n\r%d: Entering deepsleep (press user button to resume)\n", i);
habilitado=sleep_manager_can_deep_sleep();
PC.printf("can I deepsleep? %d)\n", habilitado);
if(habilitado==false){
sleep_manager_unlock_deep_sleep();
PC.printf("\n\r I couldnt but now my value is %d",habilitado);
sleep_manager_sleep_auto();
//deepsleep();
if (go_to_sleep == 5) {
myled = 0;
PC.printf("%d: Entering shutdown (press user button to resume)\n", i);
wait(1); // To let the printf finish
// Disable all used wakeup sources: WKUP pin
// Clear wake up Flag
// Enable wakeup pin WKUP2
// Set RTC back-up register RTC_BKP31R to indicate
//later on that system has entered shutdown mode
WRITE_REG( RTC->BKP31R, 0x1 );
//Enter shutdown mode
HAL_PWREx_EnterSHUTDOWNMode();
i++;
besides i dont know why board3 has that consumption.
Does anyone know why this happens or what can I do to force the board to enter deepsleep using mbed? Thanks for helping, greetings
