10 years, 11 months ago.
Any problem after the maintenance?
The system looks to be in trouble after the maintenance.
The developer.mbed.org frequently returns internal error. And the compile fails by the error 250 (Invalid buid system response).
Sorry for the disruption.
The network maintenance affected some of our network file systems which caused knock on problems with our normal automated maintenance tasks. The cause of the problem has been identified now and resolved.
Steve
I'm having the same problem. "Error: Invalid build system response." Apparently happens when linking. Sometimes the build completes but the binary has 84K instead of what it should have (400K). I used the compiler API directly and it seems the server advertises a correct content length but the response stream is truncated to 84K most of the times.
posted by 01 May 201510 years, 11 months ago.
Problems Sunday 12pm PST - Bad gateway from server nginx/1.4.6 (Ubuntu) Multiple other problems Cannot download (export) project
私も!
posted by Liyang HU 26 Apr 2015Hello. The code when compiled returns an error "unable to connect to build system" and when checked it says compile failure due to error 250.Internal error
posted by suhasini s 26 Apr 2015I am also having this problem. Unable to compile either due to error -250 or -255, and developer.mbed.org intermittently returns a HTTP 500 Internal Server error. Think something has gone horribly wrong after the upgrade.
posted by Sebastian Schocke 26 Apr 2015It's in trouble again.
posted by Nakatafu ☆ 26 Apr 2015
