8 years, 4 months ago.
Range based for loops fails
How comes my range based for loop fails with the online compiler:
std::vector<uint8_t> data; std::ostringstream oss; for (int n : data) { oss << std::setfill('0') << std::setw(2) << std::uppercase << std::hex << n; }
Error: Expected a ";" in "CaynenneLPP/CayenneLPP.h", Line: 59, Col: 17 Error: Expected an expression in "CaynenneLPP/CayenneLPP.h", Line: 59, Col: 23 Error: Expected a ";" in "CaynenneLPP/CayenneLPP.h", Line: 59, Col: 23
It's c++11, but as I read it the online compiler should be c++1 compatible
http://en.cppreference.com/w/cpp/language/range-for
Regards, Tom
Hi Tom,
Currently, the online compiler does not support C++11, if you want to use range based for loops you will have to compile your project locally using the mbed-cli tools.
Alternatively, you can use iterators
using std::vector;
for(vector<uint8_t>::iterator it = data.begin(); it != data.end(); it++){
Hope this helps, -Michael
